MHPS’ H-100 gas turbine gets multiple qualifications
MHI Group’s efforts to compete for world-scale LNG liquefaction trains continues to move forward with the completion of successive technical qualification. To date, major LNG players, including ExxonMobil, Shell, Total, along with key engineering contractors such as Bechtel, have  completed extensive qualification studies on Mitsubishi Hitachi Power Systems’ 120-MW H-100 Gas Turbine for use as the mechanical driver in conjunction with well-proven compressors of Mitsubishi Heavy Industries Compressor Corporation.
“Acceptance of our LNG Solution by customers around the globe is a real boost for the MHI team”, according to Hiroaki Osaki, President of MHI America Oil & Gas Division. “The H-100’s two-shaft design provides tremendous end-user benefits in terms of production flexibility, due to its high efficiency and wide operating range. Combined with its class-leading power density, our customers will see a step-change in lowering their production costs by taking full advantage of the potential economies of scale. For on-shore applications, our heavy-duty gas turbine is expected to yield the lowest total installed cost, lowest total life-cycle cost and highest reliability in the industry.”
The H-100 driver provides the best of both worlds, combining the efficiency and variable speed operation of an aero-derivative, with the durability, reliability and lower emissions and maintenance cost of a heavy-duty industrial gas turbine. The ability to re-start under full settle-out pressure without requiring a large external starter/helper motor, makes the H-100 the most compact, trip-tolerant driver in its class.
MHI group is now marketing their H-100-driven main liquefaction solution in single, stand-alone 1×100% strings or multi-unit large scale trains.
