Pneumofore introduces new atex-certified K series gas compressors
Vacuum pump and compressor systems specialist Pneumofore has launched its new line of K Series rotary vane gas compressor solutions, which have been specially designed to deliver optimum performance in industrial gas treatment and processing applications.
With 2.5bar(g) to 10bar(g) pressure and up to 2,690m3/h, the K Series cover the gas compression requirements of many industries, from the oil and gas and energy sectors to chemicals, from the metal industry to food processing and more.
The K Series’ high-quality, sturdy design meets the most stringent safety criteria. Moreover, these gas compressors are certified for extreme and explosive environments according to the Atex directive for Zone 1 (Atex II 2 / 2G).
The K Series gas compressors handle a wide range of gases, including methane (CH4), ethane (C2H6), carbon dioxide (CO2), nitrogen (N2), biogas and natural gas.
Each K Series compressor is designed according to the specific gas composition and application.
For this reason, a full range of accessories and optionals are available according to the customer’s needs.
The K Series gas compressors are the solution for high energy savings, low operational cost and constant efficiency over decades.
Pneumofore K Series gas compressors will be presented for the first time at Achema 2018, the world’s leading trade show for chemical engineering and the process industry, held from 11-15 June in Frankfurt, Germany.
