Self-lubricating bearings
Graphalloys are typically used in hard-to-lubricate surfaces such as dampers where dampers will not operate.
Because neither grease nor oil is used, these bushings do not attract dust or foreign matter. Grapholloy bushings and bearings eliminate oil and oiling schedules, prevent oil or grease damage to products, operate in inaccessible locations or where maintenance is difficult to perform.
Graphalloy stainless steel flange blocks are available in two-bolt and four-bolt configurations and can accommodate shaft diameters from 0.5 inches (12.7 mm) to 3.75 inches (95.2 mm). Graphalloy is suitable for temperatures of 750° F and above in non-oxidizing environments.
