Free Whitepaper Signup
FEATURED WHITEPAPERS
Corrosion and erosion. Do you know how your operation is handling it?
Real-time data delivery can tell you how your plant or asset is dealing with corrosion or erosion demands. Find out how to wirelessly monitor for metal loss from corrosion or erosion in piping, vessels and pipelines and take control long before hydrocarbon containment loss occurs.
Download now
Beyond the Manual Round in Power Plants
The role of combined cycle plants in the larger energy picture is changing, and so are the ways of managing and optimizing operations. Automation technologies for monitoring plant assets can have a significant impact on reliability, availability, heat rate and emissions by giving you valuable insight into problems before they occur.
In this white paper, we will review three steps for moving a plant beyond manual rounds, leading to improved profitability and unit performance.
Download now
Optimizing IIoT Value in Oil & Gas with IT-OT Alignment
Digital transformation is a major disruptive force facing oil & gas companies today. Operators are looking to bridge the divided worlds of information technology (IT) and operational technology (OT). Discover how your organization benefits from IT-OT alignment.
Download now
PAST WHITEPAPERS
FEBRUARY 2018
Emerson | Title: Corrosion and erosion. Do you know how your operation is handling it?
Real-time data delivery can tell you how your plant or asset is dealing with corrosion or erosion demands. With reliable corrosion or erosion events detection online, you’ll be able to take control… Download now
NOVEMBER 2017
SIFCO | Title: Whitepaper addresses corrosion issues and how to reduce downtime in turbomachinery
Electrical pitting damage, oil starvation, tin oxide damage, and thermal ratcheting are only a few of the dozens of issues… Download now
JULY 2017
Kingsbury | Title: Causes and Solutions of Fluid Film Bearing Failure
National Instruments | Title: Control Design Guide for Next-Generation Machines
Metal corrosion is a costly fact of life in the turbomachinery industry. This paper examines the causes and impact of corrosion and wear on power generation equipment… Download now
Petrotech | Title: Single Valve Fuel Gas System Retrofits
Petrotech’s single fuel valve control strategy has been refined over our 20 years of designing single fuel valve control systems… Download now
MAY 2017
4D Technology Corp | Title: High-resolution 3D Shop Floor Measurements Reduce Waste
Electrical pitting damage, oil starvation, tin oxide damage, and thermal ratcheting are only a few of the dozens of issues that can cause a fluid film bearing to fail… Download now
Emerson | Title: Improve Reliability of Turbomachinery Lubrication and Sealing System Operations
Robust, accurate control of a lubricating oil system is crucial to the overall longevity of rotating equipment… Download now
National Instruments | Title: Addressing Challenges of Fleetwide Monitoring
Download the white paper to read about the challenges maintenance managers face with improving overall reliability… Download now
Woodward | Title: Turbine Overspeed Systems and Required Response Times
Turbine overspeed events lead to the most dangerous and costly of catastrophic turbine failures… Download now
There are no products
