News|Articles|June 16, 2026
John Crane Introduces Validated Methodology to Improve Drivetrain Analysis Accuracy
Listen
0:00 / 0:00
  • Conventional constant-stiffness torsional models can mispredict critical frequencies across variable operating regimes, manifesting as commissioning-time vibration, accelerated wear, and latent failure mechanisms.
  • A torque- and condition-dependent torsional stiffness framework is used to better represent real drivetrain behavior, improving fidelity versus fixed-parameter analytical assumptions.
SHOW MORE
John Crane has introduced a validated methodology that improves drivetrain analysis accuracy by treating torsional disc coupling stiffness as dynamic rather than fixed, reducing failure risk and commissioning uncertainty for operators in oil and gas, LNG, and power generation.
John Crane has introduced a validated methodology designed to improve the accuracy of drivetrain analysis in critical rotating equipment. The approach targets a long-standing limitation in how torsional behavior is modeled—one that has quietly contributed to commissioning surprises and unplanned downtime across oil and gas, LNG, and power generation operations for decades.
Why Do Traditional Drivetrain Models Fail to Predict Real-World Behavior?
Traditional drivetrain analysis treats torsional stiffness as a fixed value, but John Crane's methodology recognizes that stiffness changes under different operating conditions and torque levels. That assumption of constancy, reasonable in simpler systems, becomes increasingly problematic as rotating equipment operates across variable speeds—producing a gap between predicted and actual behavior that can surface as vibration issues, reduced asset life, or failures that only become visible at commissioning. By combining advanced modeling, static and dynamic testing, and real-world operational data, the new methodology creates a more representative picture of how drivetrains behave in service, allowing engineers to predict critical frequencies with significantly greater precision and reduce the uncertainty that has historically accompanied start-up.
How Was John Crane's Torsional Stiffness Methodology Developed and Validated?
Developed over three years, the methodology has been validated across analytical modeling, physical testing, and live customer applications in collaboration with leading OEMs and operators. While aspects of variable torsional stiffness have been explored in academic research, John Crane characterizes its approach as industry-first on the basis of that end-to-end validation—from static and dynamic bench testing through to measurable correlation with real-world drivetrain performance. That distinction between theoretical treatment and field-proven implementation is central to the company's positioning of the work.
Steve Pennington, Global Engineering Coupling Manager at John Crane, described the development as a meaningful shift in how the industry approaches drivetrain prediction: "For years, the industry has relied on simplified assumptions that do not fully reflect real operating conditions. By validating this methodology through testing and live applications, we are giving customers a far more accurate and reliable understanding of system behavior.”
How Can More Accurate Drivetrain Analysis Reduce Failure Risk and Unplanned Downtime?
For operators in industries where unplanned downtime can cost millions per day, the benefits are practical and immediate: reduced risk of unexpected failure, greater confidence during commissioning, improved reliability and uptime, and more informed decision-making during system design. As variable speed drive adoption continues to expand across industrial applications, the accuracy demands on drivetrain analysis will only increase—making a methodology grounded in dynamic stiffness characterization increasingly relevant to how operators and OEMs approach new system design and pre-commissioning validation.
References
John Crane. "John Crane introduces industry-first methodology to improve drivetrain accuracy and reduce failure risk." June 16, 2026.
