- June 2026
- Volume 67
- Issue 2
- Pages: 31-33
A Closed-Loop Approach to Turbomachinery Asset Management
- Consolidation of analysis, redesign, manufacturing, installation, and remote monitoring reduces multi-vendor fragmentation during compressor, turbine, and pump events.
- FCAM streams real-time process and vibration variables to a shared dashboard, enabling early detection of efficiency erosion, leakage growth, and vibration drift.
Flexware brings together remote performance monitoring, root cause engineering, precision manufacturing, and field services under one roof—giving operators a true end-to-end partner for the life of their rotating equipment.
For operators of centrifugal and axial compressors, gas turbines, steam turbines, and pumps, the frustration of managing multiple service vendors across a single equipment problem is a familiar one. A vibration anomaly triggers a call to one firm for analysis, another for replacement parts, another for installation—and still another, perhaps, for ongoing monitoring once the machine is back online. Grapeville, Pennsylvania-based Flexware, Inc. is built to eliminate that fragmentation.
"If a client has a problem, we can complete the root cause analysis, redesign the affected parts, manufacture and install them for a longer trouble-free life, then monitor the machine remotely to confirm it's running clean—and if necessary, plan future maintenance according to what the monitoring forecast tells us. That full loop, handled by one team, is what sets us apart." — Ted Gresh, President & CEO, Flexware, Inc.
What Is the Flexware Cloud Asset Monitor?
At the center of Flexware's service offering is the Flexware Cloud Asset Monitor (FCAM), the company's cloud-based platform for continuous performance and vibration monitoring. FCAM collects operating data in real time—flow, pressure, temperature, efficiency, vibration, seal leakage and other process variables—transmits it securely to the cloud, and presents it through a unified dashboard accessible to both the operator and Flexware's engineering team.
The platform is built around four core functions: trending and forecasting, diagnosis, analysis, and problem resolution. Trending and forecasting capabilities allow Flexware engineers to identify gradual performance deterioration—efficiency erosion, increased seal leakage, changes in vibration—well before those trends manifest as an unplanned outage. This predictive posture converts reactive maintenance into a managed, scheduled activity, with direct consequences for operating cost and plant availability.
Diagnosis goes deeper. When an anomaly appears, FCAM's data record gives Flexware's turbomachinery engineers the raw material for a true root cause investigation—not a guess based on a single field measurement, but a time-stamped history of how the machine arrived at its current state. That diagnostic foundation is precisely what enables the next step in the Flexware model: engineering-led problem resolution.
How Does Monitoring Lead to Engineering Action?
Where many monitoring services end with a report and a recommendation, Flexware's model extends into execution. The company's engineering staff, with decades of hands-on experience in turbomachinery design and failure analysis, translates FCAM findings into corrective action.
Root cause failure analysis is available for a broad range of mechanical failure modes, including gas face seals, oil seals, bearings, impeller failures, and vibration and rotor dynamics problems. When a failure mode is identified, Flexware's aerodynamic and mechanical engineering capabilities allow the team to redesign the affected components—not simply replace them with the same part that failed.
Gas path modeling supports rerates and upgrades for both compressors and turbines, enabling Flexware to optimize a machine's performance characteristics rather than simply restore them to original specification. The company's software tools—including CompAero for compressor aerodynamic design and TurbAero for turbine design—underpin this work, and have been used by turbomachinery engineers and OEMs for years. Flex Live, Flexware's performance monitoring software, completes the software portfolio with real-time performance tracking capabilities that integrate naturally with FCAM data streams.
Finite element analysis using ANSYS is available for frequency, thermal, transient, and steady-state problems. Rotordynamics analysis—covering critical speeds, stability analysis, and damper bearing and seal design—rounds out the analytical toolkit, giving Flexware the depth to address even complex, multi-discipline failure scenarios.
What Manufacturing and Efficiency Enhancement Capabilities Does Flexware Offer?
Engineering solutions require physical execution, and Flexware supports its analysis work with the ability to supply redesigned and replacement parts. Turbomachinery spare parts—including bearings, seals, impellers, and diaphragms—are available through the company, along with Cartridge Sleeve Seals developed using Flexware's proprietary repair technology.
Efficiency enhancement programs address specific loss mechanisms within the gas path. Rub-tolerant labyrinth seals reduce leakage flows without the risk of seal-induced instability. Aerodynamic coatings improve surface finish and reduce profile losses. Impeller staging redesign can recover efficiency points lost to original design compromises or years of operational wear. These targeted interventions, applied after a proper performance analysis, deliver measurable improvement in flow capacity and compression efficiency.
What Field Service and Overhaul Capabilities Are Available?
Flexware's field service capability extends to full overhauls of compressors, pumps, gas turbines, and steam turbines. Disassembly, inspection, repair, and reassembly are performed by the same engineering team responsible for root cause analysis and redesign—a structural advantage over arrangements where field mechanics and design engineers operate independently.
Inspection services are available as a standalone offering for operators who want an independent assessment of equipment condition between scheduled overhauls, or following an operating event such as a surge, trip, or process upset.
The practical effect of this integrated model is a closed-loop lifecycle: FCAM identifies a developing problem, Flexware engineers perform root cause analysis, redesigned parts are manufactured and installed, and the machine goes back online under FCAM surveillance—with a forecasting model now informed by the actual repair history of that specific asset.
Does Flexware Offer Training and Knowledge Transfer?
Flexware also supports the broader development of operator and engineering competency through training seminars covering Flexware software tools, compressor performance principles, and general turbomachinery mechanical and aerodynamic design and operation. For organizations building internal capability, these programs complement the monitoring and engineering services by raising the technical baseline of the people working alongside Flexware engineers day to day.
Looking Ahead
The increasing push toward maximizing asset utilization and deferring capital expenditure on new equipment makes Flexware's model particularly relevant. For many operators, the most cost-effective path to improved performance is not a new machine—it is a thorough understanding of what the existing machine is doing, why, and what a well-targeted intervention can accomplish. FCAM provides that understanding continuously. Flexware's engineering and field service capabilities provide the response.
"Contact us today about your turbomachinery questions and challenges. We will be glad to share our experiences with you." — Collin Pillay, Director, Flexware, Inc.
Flexware, Inc. | P.O. Box 110 | Grapeville, PA 15634-0110 | sales@flexwareinc.com | www.flexwareinc.com
