MHI Thermal Systems Launches ETI-N Centrifugal Chiller with Magnetic Bearing Tech
- The ETI-N chiller's magnetic bearing technology eliminates lubrication needs, enhancing efficiency and reducing maintenance requirements.
- ETI-N models range from 150-700 refrigeration tons, using HFO-1233zd refrigerant to minimize environmental impact.
The magnetic bearing technology reinforces an oil-free design, eliminating the need for a lubrication oil system and preventing wear on sliding parts.
Mitsubishi Heavy Industries Thermal Systems (MHI Thermal Systems) unveiled its newly developed
Without these lubrication systems, the ETI-N removes the necessity for periodic oil replacement activities and, as a result, the unit significantly minimizes maintenance work. Unlike conventional centrifugal chillers, the ETI-N does not require an oil pump or the time to formulate the lubricating oil film. With these quick-start features, the chiller improves operational efficiency for customers.
MHI Thermal Systems’ ETI-N series is available in small- to medium-capacity models ranging from 150 – 700 refrigeration tons, featuring a standard built-in inverter to reduce transportation and installation work. Its high efficiency is reinforced by a 6.4 coefficient of performance and a 9.1 integrated part-load value. The refrigerant, HFO-1233zd, is a non-flammable, non-ozone-depleting solution with a global warming potential of 1 to reduce environmental impact.
Adding the ETI-N magnetic bearing centrifugal chiller enriches the current product portfolio, offering customers a broader range of technologies for their specific applications. MHI Thermal Systems’ portfolio combines greener environmental performance with improved equipment performance, including the:
- ETI-Z series launched in 2015 using HFO-1233zd
- GART-ZE/ZEI series introduced in 2017 with HFO-1234ze
- JHT-Y/YI series released in 2022 using HFO-1234yf
ETI-W Centrifugal Heat Pump
In early October 2025, MHI Thermal Systems launched the newly developed
The pump’s coefficient of performance is 4.01 when supplying hot water temperature of 90 ℃, and it’s capable of handling large-scale industrial capacities equivalent to a 1-ton boiler with 640-kW capacity. It is equipped with centrifugal compressors—also utilized on MHI’s centrifugal chillers—that are designed for refrigerant characteristics and high compression ratios.
The technology achieves high performance and a small footprint by using an inverter starter panel within the primary unit and a shell-and-tube heat exchanger. On the environmental side, it uses a non-fluorocarbon refrigerant—HFO-1233zd(E)—with a global warming potential of 1 and does not deplete the ozone layer.
MHI’s EC-8
Also, MHI Thermal Systems launched an updated version of its Ene-Conductor Heat Source Control System. The new
The EC-8 model supports both the individual pump system and the multiple pump system widely used in large-scale facilities built across Southeast Asia and the Middle East. It uses the BACnet protocol and Modbus to enable real-time communication and information exchange between machines and sensors, improving response time. The system contains fewer signal cables, simplifying construction management.
