A review of inspection practices, common failure modes, and maintenance planning for rubber expansion joints in power plant piping systems.
NewTek Sensor Solutions introduces the RV series of RVDT (Rotary Variable Differential Transformers) Rotary Positions that offer accurate angular displacement measurement of rotating elements such as quarter-turn ball and butterfly valves, actuators, throttles and dancer arm tensioners used in industrial machine-to-machine applications.
With a shaft that rotates a full 360° with no stops and virtually no friction, these AC-operated rotary position sensors
measure shaft angle position over a nominal range of ±30°.
