Why Driver Train Health Matters as Much as the Compressor Itself
- Understand why gearboxes and other driver-train components can require more monitoring attention than the compressor itself.
- Discover why the majority of root-cause failures trace back to auxiliary systems rather than the compressor.
Panelists explain why the equipment surrounding a centrifugal compressor can matter as much as the compressor itself.
Episodes in this series
Sponsored by FS-Elliott
It's easy to focus attention on the compressor and treat the driver train (motors, gearboxes, couplings, steam or gas turbines) as secondary. Omar Al-Essa pushes back on that instinct, explaining that gearboxes in particular can require even more monitoring and attention than the compressor they support, given how delicate and multi-staged they are.
Wael Al Mandarawi adds a striking statistic from his own root cause analysis experience: 60 to 70 percent of compressor problems trace back to auxiliary systems (couplings, seals, lube oil, electrical motors) rather than to a properly designed and selected compressor itself. Omar Al-Essa confirms the pattern, noting that compressors operated within their intended design envelope can run 8 to 12 years without a single overhaul.
For teams building a maintenance strategy, this episode reframes where attention and budget should go: not just at the compressor, but across the entire train.
