SGT-800s to support expansion of Indonesian refinery
Siemens Gas and Power has been selected to supply a range of compression and power generation equipment for the Balikpapan Refinery located on Borneo Island in East Kalimantan, Indonesia.
The facility is owned and operated by PT Pertamina (Persero). The equipment will be installed as part of Pertamina’s Refinery Development Master Plan (RDMP).
The RDMP involves the construction of a residual fluid catalytic cracker (RFCC) unit with a design capacity of 90,000 barrels per stream per day (bpsd); a liquefied petroleum gas (LPG) sulfur removal unit; a propylene recovery unit; and an 80,000 bpsd middle distillate hydrotreater.
Siemens Gas and Power’s scope of supply includes four gas turbines, 17 reciprocating compressors, along with a single-stage, hot gas expander. Specific compressor models to be provided include eight HHE-VL compressors, two HHE-FB compressors, four HHE-VG compressors, and three HSE compressors. Additionally, Siemens Gas and Power will supply four SGT-800 industrial gas turbines and five SST-600 steam turbines for the Balikpapan power plant.
The hot gas expander will recover waste heat (i.e., flue gas) from the RFCC reactor to produce approximately 20 megawatts (MW) of free power, which will be used to drive the plant’s central air blower, along with a single steam turbine. This unique arrangement will reduce overall steam consumption and result in significant operational cost savings for Pertamina.
The expansion project will increase the output of the Balikpapan refinery from 240,000 barrels per day (BPD) to 360,000 BPD. The project will also enable the refinery to produce high-quality fuels of the Euro V standard.
All the reciprocating compressors will be manufactured in Siemens Gas and Power’s Naroda Gujarat plant in India. The hot gas expander will be built in Olean, New York, USA, the steam turbines will be manufactured in Görlitz, Germany, and the gas turbines will be manufactured in Finspong, Sweden.
Installation and commissioning of the equipment are slated for 2022.
Four SGT-800 industrial gas turbines will enable the cost-effective expansion of the Balikpapan refinery.
Siemens SST-600 steam turbine tailor-made design; actual design depends upon project conditions.
