Feature|Videos|November 19, 2026
Engineering Better Compressor Performance with Polymer Labyrinth Seals – Mitsubishi Chemical Advanced Materials
  • Understand how the tighter clearance capabilities of polymer labyrinth seals, compared with standard metallic seals, support compressor efficiency, throughput, and reliability.
  • Learn why polymer seal teeth return to their original dimension after contact, while metallic seals can mushroom and permanently lose efficiency.
SHOW MORE
Jesse Garcia, manager of business development at Mitsubishi Chemical Advanced Materials, makes the case for rethinking what goes into a compressor’s labyrinth seals.
Sponsored by Mitsubishi Chemical Advanced Materials
Jesse Garcia, manager of business development at Mitsubishi Chemical Advanced Materials, discusses how polymer labyrinth seals can improve compressor performance and reliability. Garcia explains that polymer labyrinth seals offer tighter clearance capabilities than standard metallic seals. Those tighter clearances support efficiency, greater throughput, and smoother, more reliable operation of compressor equipment.
A central theme is what happens when a labyrinth seal experiences contact. According to Garcia, the metallic seals in use today develop a mushrooming effect on contact, resulting in a permanent loss in efficiency, while the teeth of a polymer seal return to their original dimension. He describes polymer seals as forgiving and self-lubricating, able to handle chemical compatibility and wear while remaining efficient throughout the compressor’s life cycle. Garcia also outlines what engineers should consider when selecting a seal material, including temperature, pressure, wear, and rotating speed, and notes that Mitsubishi shares dynamic modulus analysis and stress-strain curves with customers to help recommend the right material, backed by extensive testing that includes a flex modulus of more than 1 million.
Garcia closes by describing Mitsubishi’s approach to partnering with end customers: understanding their needs and goals, sharing technical expertise, and working toward the shared goal of extending equipment life. Engineers and operators responsible for compressor equipment will come away with a clearer understanding of how seal material choice affects efficiency, reliability, and performance over the life of their machinery.
