News|Articles|September 22, 2026
Ebara Elliott Expands Houston Turbomachinery Repair and Testing Center
Listen
0:00 / 0:00
  • A 23,000-square-foot expansion consolidates end-to-end compressor, turbine, and rotor overhaul activities to reduce vendor handoffs, transportation delays, and outage-schedule risk for process and energy operators.
  • In-house overspeed spin testing mechanically validates impellers through 110M frame size (up to 76-inch diameter), enabling tighter integration of test findings into repair decisions and faster return-to-service.
SHOW MORE
Ebara Elliott Energy expands its Houston center with in-house machining, welding, spin testing and multi-OEM turbomachinery services.
Ebara Elliott Energy has expanded its Houston Center of Excellence, creating a single-source hub for turbomachinery repair, component manufacturing, testing and rotor restoration serving energy and process-industry operators across the Americas.
The multimillion-dollar project adds 23,000 square feet of shop floor space and consolidates several critical overhaul functions at one location. According to Ebara Elliott Energy (EEE), the expanded center can support compressors, turbines and rotors manufactured by EEE and other original equipment manufacturers.
“Whether a customer is running EEE equipment or another manufacturer's fleet, our team in Houston now has the complete in-house capability to inspect, weld, machine, balance, spin test, and return critical machinery to service with unprecedented speed.”
The investment is designed to reduce dependence on external vendors and overseas facilities. For plant operators, bringing inspection, welding, machining, balancing and testing under one roof could simplify outage planning while limiting transportation and supplier-interface delays.
What capabilities were added in Houston?
A central feature is an in-house overspeed spin-testing pit capable of mechanically validating impellers through the 110M frame size, representing diameters of as much as 76 inches. EEE said the test capability verifies mechanical integrity before components are returned to field service.
Locating spin testing alongside repair and manufacturing operations can reduce the need to transport an impeller between separate service providers. It also allows findings from testing to be integrated directly into the repair workflow, an important consideration when turnaround time governs whether machinery can return during a scheduled outage window.
The Houston center also includes submerged arc welding and precision laser welding cells. EEE said these processes will be used to restore damaged shafts, impellers and rotors to original OEM specifications.
Supporting equipment includes in-house CNC machine tools and cylindrical grinders. The company has also established an on-site inventory of standard material forgings, intended to shorten lead times when a critical replacement part must be manufactured during an overhaul.
How will the center support multi-OEM equipment?
EEE is positioning the Houston facility as a full-fleet service center rather than an exclusively OEM-specific shop. Its stated scope includes complete repairs, overhauls and rerates for both EEE and non-EEE rotating equipment.
High-precision 3D optical scanning and coordinate measuring machine inspection suites provide the dimensional data needed to reverse-engineer replace-in-kind impellers and wear components. For plants operating machinery from multiple suppliers, that capability could consolidate procurement and technical coordination through one service location.
The center also has access to regional partners for high-velocity oxygen-fuel coatings, specialized surface treatments and five-axis milling. This local network complements the work performed directly within the expanded facility.
What does the expansion mean for outage planning?
The primary operational implication is a more integrated repair sequence. Inspection findings can move into weld restoration, machining, dimensional verification, balancing and spin testing without routing the component through several geographically separated vendors.
“Unplanned downtime is the single biggest threat to our customers’ operational margins, and managing multiple repair vendors only adds risk and delay,” Shane Reph, EEE’s deputy CEO and chief operating officer, said in the expansion announcement. "We expanded our Houston Center of Excellence to create one of the most comprehensive single-source turbomachinery facilities in the Western Hemisphere. Whether a customer is running EEE equipment or another manufacturer's fleet, our team in Houston now has the complete in-house capability to inspect, weld, machine, balance, spin test, and return critical machinery to service with unprecedented speed."
For turbomachinery managers, the broader value will depend on execution across the complete overhaul chain. The Houston expansion gives EEE control over more of that chain, from initial inspection and reverse engineering to final mechanical validation, while providing a regional option for complex compressor, turbine and rotor work.
Reference
  1. Ebara Elliott Energy, “Ebara Elliott Energy Unveils Expanded Single-Source Turbomachinery Hub in Houston,” Sept. 21, 2026
