News|Articles|July 17, 2026
Turbomachinery International
  • June 2026
  • Volume 67
  • Issue 2
  • Pages: 23-25
Material Matters: Engineering Polymer Components to Extend Pump MTBR
Listen
0:00 / 0:00
  • Uptime is frequently limited by wear rings, bushings, bearings, and sleeves exposed to friction, abrasives, corrosives, and transient hydraulic events rather than by primary metallic pump structures.
  • Metallic wear components can gall during brief contact, and corrosion/erosion progressively increase clearances, elevating internal recirculation, reducing hydraulic efficiency, and accelerating degradation.
SHOW MORE
Advanced composite materials for wear rings, bushings, bearings, and shaft sleeves are helping pump operators reduce failure risk, maintain tighter clearances, and significantly extend pump reliability and mean time between repair.
In modern pumping systems, reliability is rarely dictated by the large metallic components that dominate pump architecture. Instead, operational uptime is often determined by smaller but highly critical components such as wear rings, bushings, bearings, shaft sleeves, and other internal components that operate under continuous friction, hydraulic forces, and chemical exposure.
For engineers focused on maximizing Mean Time Between Repair (MTBR), the material selection for these components has become a strategic design decision. Advances in engineered polymer composites are enabling pump designers and operators to significantly improve reliability, efficiency, and lifecycle performance compared with traditional metallic solutions.
What Reliability Challenges Do Pump Systems Face?
Pumps operating in industries such as oil and gas, chemical processing, power generation, and water treatment face an array of demanding conditions: abrasive particulate in process fluids, corrosive chemicals and aggressive media, elevated temperatures and pressure fluctuations, hydraulic instabilities and transient events, and occasional dry-run conditions or loss of lubrication.
These conditions impose continuous stress on internal wear components. Traditionally, metallic materials were widely used for wear rings, bearings, and bushings. While metals provide structural strength, they introduce several challenges in dynamic pump environments. Metal-to-metal contact during transient events can lead to galling and rapid wear that can lead to catastrophic pump failure. Additionally, corrosion and erosion can degrade performance over time, gradually increasing clearances within the pump. As clearances grow, internal recirculation increases, reducing hydraulic efficiency and accelerating component degradation.
How Do Engineered Polymer Composites Address These Challenges?
Over the past several decades, advanced polymer composites have emerged as an effective alternative for pump wear components. Unlike traditional thermoplastics, modern composite materials are engineered with reinforcement fibers, fillers, and proprietary formulations designed specifically for rotating equipment environments.
These materials offer several advantages: improved wear resistance against abrasive particles common in process fluids; lower friction characteristics that minimize heat generation and wear rates; corrosion resistance in many aggressive chemical environments; superior vibration damping compared with metals; and touch-off survivability during transient events where rotating and stationary components momentarily contact. Reduced running clearances also deliver increased flow rate and pump output, and lower overall energy consumption.
How Do Tighter Clearances Improve Pump Efficiency?
One of the most significant advantages of engineered polymer wear components is the ability to operate with tighter clearances within the pump. Tighter running clearances between wear rings and shaft components reduce internal recirculation of process fluid, improving hydraulic efficiency and reducing energy consumption over the life of the pump.
However, maintaining tight clearances requires materials capable of surviving occasional contact without catastrophic damage. Traditional metal components can suffer severe scoring or galling during such events. Engineered polymer composites are uniquely suited for these conditions—their wear behavior allows the materials to absorb transient contact events while protecting the mating metal surfaces from damage, enabling pump designers to pursue more aggressive efficiency targets while maintaining reliability.
What Polymer Materials Are Designed Specifically for Pump Applications?
Not all polymers are suitable for rotating equipment environments. Successful pump applications require materials engineered for a combination of mechanical strength, dimensional stability, and chemical compatibility. Advanced composite materials such as CDI Products' dures® family were developed specifically for pump wear components including wear rings, bushings, bearings, and shaft sleeves.
Different material formulations can be optimized for specific operating conditions. Carbon-fiber reinforced composites offer high strength and dimensional stability. PFA-based compounds provide exceptional resistance to aggressive chemicals. High-temperature composites allow continuous service in elevated temperature environments. By tailoring the composite structure to the application, engineers can address specific challenges such as abrasive slurries, corrosive chemicals, or high-speed pump operation.
What Is the System-Level Impact on Reliability?
While material upgrades may appear incremental at the component level, their impact on system reliability can be substantial. In many industrial facilities, pumps represent a significant portion of unplanned maintenance events. Even modest improvements in wear component durability can translate into meaningful increases in MTBR across large pump populations.
The benefits extend beyond maintenance intervals: reduced equipment downtime, improved hydraulic efficiency, lower energy consumption, reduced spare parts inventory, and lower total lifecycle cost. For operators managing critical process infrastructure, these improvements contribute directly to operational stability and profitability.
About CDI Products
CDI Products, a Michelin Group Company, is a global materials engineering and manufacturing leader delivering high-performance polymer and flexible graphite solutions to customers worldwide. With operations spanning North America, Europe, the Middle East, and Asia-Pacific, CDI designs and manufactures mission-critical seals, bearings, wear components, and functional components for the world's most demanding environments. Learn more at www.CDIproducts.com.
