What Gets Missed in Troubleshooting: How Small Issues Cascade
- Discover why the root cause of a compressor problem is often found in the auxiliary systems, not the compressor itself.
- Learn how small, ignored issues accumulate into major failures over time.
FS-Elliott's Shady Saeed and Saudi Aramco's Omar Al-Essa reveal where compressor problems really start, and it's rarely where operators are looking.
Episodes in this series
Sponsored by FS-Elliott
Root cause analysis often reveals that a failure's true origin sits days, weeks, or even months before the actual event. In this episode, Shady Saeed explains that from an OEM perspective, it's usually the auxiliary systems (intake filters, heat exchangers, controllers) that get missed, because instrumentation and monitoring tend to focus on the compressor's core rather than the package around it. He walks through how something as simple as an inadequate air intake filter can lead to erosion, fouling, and rising vibration that masks the actual root cause.
Omar Al-Essa builds on that point, describing how small issues accumulate silently until a compressor reaches a threshold it can no longer absorb. Drawing on his experience with rotating equipment in extreme ambient heat, he points to cooling systems, lube oil pressure, and heat exchanger cleanliness as common culprits, issues that get ignored specifically because redundant equipment lets facilities keep production running rather than address the problem.
This episode is a practical reminder for maintenance and reliability teams: the auxiliaries around a compressor deserve as much attention as the machine itself.
