Feature|Videos|November 25, 2026
Lessons Learned: Real-World Compressor Lifecycle Decisions
  • Learn how one operator extended compressor life by adding capacity instead of replacing existing units.
  • Discover how a changing gas-to-oil ratio led one plant to install an adjacent compression system rather than scrap working equipment.
SHOW MORE
Wael Al Mandarawi and Omar Al-Essa share real-world examples of how their teams extended compressor life instead of scrapping working equipment.
Sponsored by FS-Elliott
Rather than treat every aging or capacity-constrained compressor as a candidate for replacement, this episode's panelists share how they've found alternatives. Wael Al Mandarawi describes how, when air demand grows, his team adds compressors rather than replacing existing units that are still running without failure, while noting that process and gas compressors are less flexible, since the driver often has to change alongside the compressor.
Omar Al-Essa shares a specific example from just before the COVID-19 pandemic: as the gas-to-oil ratio of the oil wells his team supported shifted, mid-1990s compressors could no longer serve as the primary compression equipment. Rather than replace them outright, the team installed an adjacent new compression plant with its own dehydration system and added a jumper connection between the old and new units, increasing operational flexibility to use them interchangeably.
These field examples offer plant teams a practical playbook for extending asset life when demand or process conditions shift.
